H440 Water Cooling Build
Yenko
Nice build! I took the heatsink plates off my Z77 Mpower as well. If you go into the BIOS, in the "Eco" menu on the left you can find the option to turn off the blue lights on the motherboard if you want.
Case: Silverstone TJ07 CPU: i5 3570K Motherboard: Asus Z77 Sabertooth RAM: Dominator Platinum 8GB GPU: SLI GTX 970 G1 Storage256GB Samsung 840 Pro + 3TB WD Green PSU: Corsair RM850 Monitor: Asus PB278Q Cooling: Water cooling with acrylic tubes HeadphonesPhilips Fidelio X2 DAC: Schiit Modi Amp: Schiit Vali
  • 2 weeks later...
You dont need to go in to the bios, you can turn off the blue light in the MSI control center
System : I7-6700K EK-Supremacy. . Gigabyte Z170X-UD5 TH . 16GB Kingston HyperX predator ddr4. Evga Supernova 750 G2. Samsung 850 250gb. Samsung 840 250gb.
Evga GTX780 Classified EK-780 Classy . NZXT H440 White. Alphacool ST30 240. HW Labs SR-1 360. Alphacool D5 vario. aquacomputer D5 pump/res combo  . logi G502. CM Quick fire blue.  Dell U2515H.
  • 2 months later...
Hey some of the hoses are starting to kink, did i choose the wrong size tubing 13/10 over 10/16
post-34129-0-93363900-1416844699_thumb.j
post-34129-0-06013200-1416844716_thumb.j
  • 8 months later...
Update new Mobo, cpu, and ram
post-34129-0-35500800-1440172538_thumb.j
  • 4 months later...
So the new asus z170A mobo died yesterday, so here is a little update on the build.
New mobo Gigabyte Z170X-UD5 TH
and new psu Evga Supernova 750G2
post-34129-0-21853200-1450878310_thumb.j
post-34129-0-44607300-1450878320_thumb.j
post-34129-0-61080000-1450878328_thumb.j
post-34129-0-46275700-1450878339_thumb.j
CPU Intel Core i7 4790K Motherboard EVGA Z97 Stinger Core-3D GPU EVGA GTX 980Ti SC+ Storage 128 GB Samsung 850 Pro, 512 GB Samsung 850 EVO, 750GB HDD PSU Silverstone SX600-G Case Dan Cases A4-SFX v1 Cooling Custom Loop Monitor Acer Predator XB271HU (1440p), ASUS 1080p Keyboard TADA68 Mouse Logitech G502 Build Log Link
Was actually planning on making a build with the Krait and NZXT H440. Sadly I don't have the money to justify the cost of water cooling a locked Intel CPU so I might get a Cryorig H7 or C7, not sure yet.
i5 4590 @ Stock, XFX R9 290!, HyperX Beast 4x8GB  @1600, 850 EVO 120gb, WD Caviar Blue 1TB, , Asrock H97m Pro 4 , Fractal Design Define R4, Windows 10
Yeah I'm still planning on swapping out to 4790k hopefully soon
That looks great, did u paint the bracket for that ek cpu cooler
I did. Also painted the screws it comes with. (They were silver before).
Next project will be hardline tubing PETG
and maybe  paint the heatsink black on the new mobo
