Can't decide between two cases, need Help!
14 hours ago, Ramotovski said:
Hi,
I've narrowed down my search to these two:
- Aerocool Quartz Red Midi-Tower
- Phanteks Eclipse P300
Which one would you recommend?
Thanks in advance :D
P300 has better airflow, even though the Aerocool has 4 fans, the front fans have a very tiny strip of ventilation space around the sides of the front glass. I would get the P300 and buy an extra fan or 2 for around $10 (or equivalent) and mount them at the front of the case.
