prolimatech megahalems (comes in black red and blue and without fans )
158mm height, so a tight fit.
the evo 212 i currently have is 159. so it should fit. ^^
"Probably Because I'm A Dangerous Sociopath With A Long History Of Violence"
https://linustechtips.com/topic/99987-quiet-cpu-cooler/page/2/#findComment-1337652
i5 3570k @4Ghz with 1.25v
Look into the Noctua NH-U12S and the NH-U14S.
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/99987-quiet-cpu-cooler/page/2/#findComment-1337656
the 14s is too high, but the 12s is good. Only problem is, it's silver, too. ^^ that's the reason why I'm changing. xD
https://linustechtips.com/topic/99987-quiet-cpu-cooler/page/2/#findComment-1337660
Read some reviews on the prolima, it's like the awesome underdog cooler, that also looks great.
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
https://linustechtips.com/topic/99987-quiet-cpu-cooler/page/2/#findComment-1337670
You could also just buy good fans and spray paint the top of your 212 in a matching color. I'd suggest bequiet silent wings 2 pwm and spray paint the top in a mat black.
Other coolers to look out for: Phanteks PH-TC12DX (doesn't really improve  cooling) and Phanteks PH-TC14PE (maybe incompatible with RAM.)
I am not sure about the noise of the phanteks coolers. All i know is that they are extremeley well built and can compete with bequiet and noctua and such.
who cares...
https://linustechtips.com/topic/99987-quiet-cpu-cooler/page/2/#findComment-1337680
the first one looks great, the second one doesn't fit with the case. ^^
https://linustechtips.com/topic/99987-quiet-cpu-cooler/page/2/#findComment-1337685
this thing doesn't get enough praise.
It's 66 and probably in the mid to low 70's ambient in my room and it can keep my chip cool enough to browse the forums, imgur, etc passively in my heat trap R4
literally the fans aren't moving right now.
Error: 410
https://linustechtips.com/topic/99987-quiet-cpu-cooler/page/2/#findComment-1341491
snip
I once had to run my 4670K /w Dark Rock 2 passiveley for a couple days. With light use it never went over 45.
But a FX 8 core passiveley is impressive! :D
I'm not too happy with my Dar Rock 2, but i allwayws looked at dem phanteks coolers. But they're so expensive! O.o
btw. what program did you use to control the CPU fan within Windows?
who cares...
https://linustechtips.com/topic/99987-quiet-cpu-cooler/page/2/#findComment-1341649
Easy tune 6, Gigabyte BIOS utility.
Error: 410
https://linustechtips.com/topic/99987-quiet-cpu-cooler/page/2/#findComment-1342956
Noctua NH-D14 or Corsair h60
AMD FX-8320 @ 4.3 ghz | Corsair H60 (Push/Pull)|  8GB Kingston Hyper X DDR3 1.6 ghz | Sapphire HD 7870 Oc'd | Biostar TA970 MOBO OCZ 750w  PSU | 2TB HDD + 120gb Kingston V300 SSD| Coolermaster CM Storm Enforcer Case | SoundBlaster Audigy SE  Windows 7        "I am a leaf on the wind, watch me..."   "You know nothing Jon Snauhh" "Take the risk of thinking for yourself, much more happiness, truth, beauty, and wisdom will come to you that way."
/Steam Profile/Folding@home stats/TekSyndicate Fourms/  \m/  RIP David Gold (1980-2011) \m/ RIP Peter Steele (1962-2010) \m/ RIP Chuck Schuldiner (1967-2001) \m/ RIP Dio (1942-2010) \m/ RIP Cliff Burton (1962-1986) \m/ RIP Dime (1966-2004)
https://linustechtips.com/topic/99987-quiet-cpu-cooler/page/2/#findComment-1343118
Hello Folks!
I'm looking for a good/quiet CPU cooler, that is compatible with the Venegance RAM. (the high profile one)
I currently have the EVO 212. I know it's a great cooler, but I just don't like the look of it.
Budget is 50$-70$ if needed.more.
Case is 350D, so keep in mind the height.
Thanks! :)
if you really want the be quiet ones, wait for the Dark Rock 3. they shaved off the height and it's just 160mm now.
http://www.bequiet.com/en/cpucooler/483
https://linustechtips.com/topic/99987-quiet-cpu-cooler/page/2/#findComment-1360289
