Hello Folks!
I'm looking for a good/quiet CPU cooler, that is compatible with the Venegance RAM. (the high profile one)
I currently have the EVO 212. I know it's a great cooler, but I just don't like the look of it.
Budget is 50$-70$ if needed.more.
Case is 350D, so keep in mind the height.
Thanks! :)
"Probably Because I'm A Dangerous Sociopath With A Long History Of Violence"
https://linustechtips.com/topic/99987-quiet-cpu-cooler/
My Be Quiet! Dark Rock Pro 2 was inaudible when I had it, and is pretty nice looking for an air cooler of that size.
Noctua NH-D14 is a little les quiet, but slightly better performing option.
Edit: DRP2 DOES NOT FIT, sorry: http://forum.corsair.com/v2/showthread.php?p=666720
NH-D14 might, 160mm height vs 160mm clearance, honestly I wouldn't take the risk.
THE signature
https://linustechtips.com/topic/99987-quiet-cpu-cooler/#findComment-1337537
Size may be a problem, I'll check
I pretty sure, they both don't work with the high profile vengeance ram. correct me if I'm wrong.
https://linustechtips.com/topic/99987-quiet-cpu-cooler/#findComment-1337543
It will be either very close or no
Check my edit, both the pro and non-pro do not fit, unfortunatly.
That's what I thought. My brother is using the Pro 2 and it already touches his Ripjaw Sniper ones. ^^ What are your thought on a AIO H60? Or just the Dark Rock 2?
https://linustechtips.com/topic/99987-quiet-cpu-cooler/#findComment-1337567
You might want to look into a cheap AIO watercooling solution.
Such as an H60
I was looking at that one, I really like the look of it. But my guess is that the price to performance is much better on air cooling. Am I right?^^
https://linustechtips.com/topic/99987-quiet-cpu-cooler/#findComment-1337570
Dark rock 2 doesn't fit either (height issues) and although. I have no experience with the H60, the pump on my H90 is nowhere near silent. But I've heard different stories. You can also just mount a Silent Wings 2 fan on your 212, or go with the Noctua NH-C14 (might have RAM issues as well).
THE signature
https://linustechtips.com/topic/99987-quiet-cpu-cooler/#findComment-1337581
The püroblem isn't the fan opr the loudness of the 212. I just don't like the silver look of it.:)
https://linustechtips.com/topic/99987-quiet-cpu-cooler/#findComment-1337592
Yeah, I figured it might have been the fan. Then I would say go with something like the H60 or the H75, although it won't be the most quiet or best performing option. But it looks friggin nice.
THE signature
https://linustechtips.com/topic/99987-quiet-cpu-cooler/#findComment-1337600
you can always just take off the heat spreaders. They don't do much of anything and are just there for style.
you won't be able to see it when your heat sink covers it anyway.
yeah, but i think they're to big  for the 350D. It says so anyway.^^
https://linustechtips.com/topic/99987-quiet-cpu-cooler/#findComment-1337605
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/99987-quiet-cpu-cooler/#findComment-1337627
bequiet! Dark Rock Pro 2, and Noctua NH-D14
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/99987-quiet-cpu-cooler/#findComment-1337630
already suggested. they don't work with both, my ram and my case.
but thanks. :)
WhatCPU do you have and what voltage/clock speed is it at?
https://linustechtips.com/topic/99987-quiet-cpu-cooler/#findComment-1337640
prolimatech megahalems (comes in black, silver, red and blue and without fans )
158mm height, so a tight fit.
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
https://linustechtips.com/topic/99987-quiet-cpu-cooler/#findComment-1337642
