case H500 and PSU Help
Solved by FARAWAYPLACE98,
17 minutes ago, Cereal5 said:So... Is the case on the ground? Is the ground carpet or hardwood? If there are ventilation holes, then you will be fine mounting the PSU fan up.
It's on hardwood
Featured Topics
Shane Martin ·
Posted in Displays1 -
5
INotPablo ·
Posted in CPUs, Motherboards, and Memory2 -
PatRed ·
Posted in New Builds and Planning7 -
Manv2000 ·
Posted in Troubleshooting0 -
8
QMalcolm ·
Posted in General Discussion3 -
FrozenHydrangea ·
Posted in Troubleshooting4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
