Hey Guys,
so I recently got an Asus GTX780 Ti and ive been playing Battlefield 4, while playing it the temperature of the GPU has been around 80 degrees celsius. Is this normal?
All help is appreciated, thx :)
CPU: i5 4670k @ 3.4 Ghz MOBO: Asus Z87 Sabertooth RAM: Corsair Vengeance 2 x 4gb @ 1866Mhz GPU: GTX 780 Ti Case: Corsair 750D HDD: Kingston 120gb, WD 500GB & WD 1tb PSU: Corsair Rm 750w with Blue Sleeved Cables Monitors: Acer 24", Acer 21", Samsung 18" CPU Cooling: Cooler Master Seidon 120M Keyboard: Roccat Ryos MK Pro Mouse: Razer Death Adder Speakers: Edifer 5.1 Surround Sound Microphone: Blue Yeti
PcPartPicker: http://pcpartpicker.com/user/LozzaNewport/saved/4dT0
https://linustechtips.com/topic/99914-780-ti-overheating-help-please/
Hey Guys,
Follow your topic so you know when people reply to it bud
Current Build: Case: Define R4 White/Window CPU: i5 3470 @4.0Ghz GPU: GTX 680 DCUII +500Mhz(Mem) Cooler: Hyper 212 EVO Monitor: Acer Monitor 1920x1080 MOBO: Asrock Z77 Extreme 4 Storage: 2TB HDD, 120GB 840 EVO (OS)
Future Build: 4670K, GTX 780 MSI TwinFrozr OC, Z87X-D3H, 8GB @1866Mhz, 120GB SSD, 1TB HDD, 750D, RM 650W, Custom Loop. White/Blue/Black Colour Scheme. I literally cannot wait *_*
80 isn't a problem. If it runs much higher than 90 it could cause trouble.
But it's because of Nvidia's GPU boost 2.0. It inceases clocks within a specific thermal limit (In your case 80 degrees)
I'm his friend, is the 780 ti supposed to idle at 45-50C?
It is fine, If you are worried about it you can increase the airflow in your case, customize your fan curve to ramp up more or go full out and make a tripple 360 rad GPU loop...
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
That would depend on how good the airflow is in his case. I'd say 45-50 is a little high. But it could be because his case is crammed or if his fans are not moving a whole lot of air. :)
thats fine, some of AMDs gpus goes up to 95 degrees
Thanks, i thought it was a tad broken or something
It´s perfectly fine, but if he is concerned about it he can just download MSI Afterburner/ASUS GPU tweak or EVGA Precission X and ramp the fans up :)
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
He is using an NZXT Phantom 630 or 530 sorry forgot, but the airflow is completely, fine absolutely impeccable. I thought it was a bit high as my GPU idles at around 30C on a reasonably warm day. Even with his case fans cranked up to the highest speed, nothing seemed to have changed :/ it is a reference design card, but would that really make it idle at 45-50C? Anyway thanks for the help :D
at 81% fan speed and an boost clock of 1200Mhz (forgot how much I pushed it overclocking wise) running Unigine Valley, he was getting into the mid 70s, how are those temps? I myself don't have a 780 Ti so I am not sure about what temps to expect, my gpu idles at 30 and under load playing BF4 only gets to about 50C on the lowest fan setting. He only lives 30 secs from me walking, I would imagine him to get similar temps. Thanks for the help however!
That is perfectly normal if not a little bit better so nothing to be concerned about :)
Tor
ahh alright, well thanks, yeah when I first saw it, I was a bit shocked as to why it was running so hot, my gpu is the GTX 680 ASUS DCUII OC, and it runs super cold, even with a +500Mhz on the memory clock. 'tis aftermarket though. Anyway thanks bud!
You can try to download Afterburner or Precision X. Then you should be able to make your own fan curves :) But if it's 45-50 idle I assume the fan speed is really low?
