Hey, everyone has been so helpful with getting me up speed with all this overclocking business, and I seem to be able to get much more straight forward answers here than doing other searches..so, thanks!
I've got a Ryzen 1700x that I've now got overclocked to 4.1 ghz, and the voltage pushed up to about 1.425.  When I input, say 1.45 on the voltage it grays out the number, so that essentially told me to not push my luck until I consulted those who are smarter and more experience than I am.  You guys and gals!
Is that just the mobo's BIOS being cautious, or is that an actual limit I shouldn't try and push through?  Also, I should ask if that's considered a "safe" voltage to continuously run my CPU at?
Thanks in advance.
https://linustechtips.com/topic/997940-cpu-oc-voltage-advice/
It is a number you shouldnt push through unless you have some overkill cooling.
Desktop benching:
https://linustechtips.com/topic/997940-cpu-oc-voltage-advice/#findComment-11991190
Thanks in advance.
you are also very lucky to get 4.1 on a 1700, that's the highest any 1700 goes.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/997940-cpu-oc-voltage-advice/#findComment-11991293
i think it's a warning 1. you need very good cooling when going over that amount. and 2. i believe motherboard manufacturers test their boards and those kind of voltages to test not only cpu temps but also to stress the vrm's.
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/997940-cpu-oc-voltage-advice/#findComment-11991680
