Hello everyone
I am faceing an odd problem with my PC
I got myself a new pc after my last one fried itself.
When i open MS Edge i have almost no problems browsing, but any other browser i open, (for example google chrome, opera, enz.) I get the message "This site can't be reached)
also i am having trouble with discord voice chats, and all other side apps that requires a internet conection like games, OBS.
These problems occured after a windows update.
All drivers are installed
Everything is conected properly
Windows is all up to date (and legal)
Hope i gave enough information, if not feel free to ask.
Things i tried:
- windows recovery
- drivers manually installed
- reset my modem
- changed DNS 1.1.1.1 (1.0.0.1)
Specs:
asus prime x470-pro
amd ryzen 7 2700x 8core 3.2GHZ
16gb corsair RGB 3000
samsung 500gb 860 evo m.2
1tb wd blue
gigabyte gtx 1080ti 11g oc black
corsair cx750m
windows 10 pro
https://linustechtips.com/topic/996950-help-no-internet/
My guess would be that Edge was setup with a proxy server and your other browsers and applications are not setup with a proxy server. In Edge go to Settings > View Advanced Settings > Open Proxy Settings and see if there is anything under the manual proxy settings section.
If this is not it, go back to basics; See if you can ping 8.8.8.8. If this works you can access the internet. Next ping google.com. If this works your DNS is setup correctly.
If both pings work, then the issue is not with your network setup and must be application based.
https://linustechtips.com/topic/996950-help-no-internet/#findComment-11995399
