my cpu
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/996566-used-parts/#findComment-11979823
8 minutes ago, Paddyboy1959 said:
Does anyone use used parts in their builds? Motherboards, CPU's, GPU's.
Yes.
Just now, Paddyboy1959 said:
To be clear, i'm talking about buying parts from Craigs list and other places.
I am too.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/996566-used-parts/#findComment-11979851
nah ive been a prebuilt buying pleb until i got into building PCs and game development last year and i am yet to build my first PC
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
https://linustechtips.com/topic/996566-used-parts/#findComment-11979857
All the time.  The only part I'd be reluctant to buy used is storage, although I did risk it once and managed to pickup a Samsung 850 EVO that was effectively brand-new.  I'm guessing they already had an SSD from an old PC and just sold the brand-new ones from their new pre-built PC.
My last two GPUs were brand new, but purely because I had a credit account with the store.
https://linustechtips.com/topic/996566-used-parts/#findComment-11979864
Northern Bee:
GPU, CPU, RAM, all my fittings, raiators and the reservoir.
Toaster:
Motherboard, HDD, case
G5:
PSU, HDD, GPU, case
Used parts are a great way to save a load of cash :D
Builds:
https://linustechtips.com/topic/996566-used-parts/#findComment-11979865
I've been using hand me downs for years. My wife is a computer assassin so I take her old ones, fix them and run them till they die.
https://linustechtips.com/topic/996566-used-parts/#findComment-11979869
My router uses a used CPU, my server uses a used CPU and RAM, my gaming PC is brand new apart from used RAM.
NEVER buy a used PSU though, its far too important and the part that tends to age and fail over time and if you don't know how its been abused it could easily fry the rest of the PC when it goes.  At the very least the fans can go dodgy.  Granted that can happen on GPUs too but a GPU with a good cooler usually last well.
https://linustechtips.com/topic/996566-used-parts/#findComment-11979870
