so i'm having an issue with adblock plus where if i try to load a page it will sit there loading for an eternity, and in the bottom left it will say "waiting for extension adblock plus"
i'm using Chrome on macOS High Sierra.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/995485-adblock-plus-problem/
I recently switched to u block because of similar problems. I would suggest that or reinstalling adblock.
also i like your profile picture again
CPU:R9 3900x@4.5Ghz RAM:Vengeance Pro LPX @ 3200mhz MOBO:MSI Tomohawk B350 GPU:PNY GTX 1080 XLR8
DRIVES:500GB Samsung 970 Pro + Patriot Blast 480GB x2 + 12tb RAID10 NAS
MONITORS:Pixio PX329 32inch 1440p 165hz, LG 34UM68-p 1080p 75hz
https://linustechtips.com/topic/995485-adblock-plus-problem/#findComment-11971157
already reinstalled it.
She/Her
https://linustechtips.com/topic/995485-adblock-plus-problem/#findComment-11971163
Maybe the extension is blocking the page? have you tried checking your block lists?
https://linustechtips.com/topic/995485-adblock-plus-problem/#findComment-11971172
Use the chrome ublock extension instead.
https://linustechtips.com/topic/995485-adblock-plus-problem/#findComment-11971193
Install Pihole and put it on your router and all devices will block adsvon your network
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/995485-adblock-plus-problem/#findComment-11971476
i'd rather not do that, because i'm often away from home. i'd like a solution that works everywhere.
i switched to ublock, but i don't like it... it's difficult to get to the preferences of it and once you get there, sending ping traffic and "anonymous" data is enabled...
She/Her
https://linustechtips.com/topic/995485-adblock-plus-problem/#findComment-11971481
1 hour ago, yamileon said:
just making sure you did get the one by raymond hill
right
what do you mean?
She/Her
https://linustechtips.com/topic/995485-adblock-plus-problem/#findComment-11972251
13 hours ago, firelighter487 said:
what do you mean?
There are two versions of uBlock.
uBlock and uBlock Origin. The one the community refering is uBlock Origin.
Here - https://chrome.google.com/webstore/detail/ublock-origin/cjpalhdlnbpafiamejdnhcphjbkeiagm
There has been some problems in the past between the devs of the OG uBlock, Which led to the birth of uBlock Origin.
I suggest reading this to understand the difference between uBlock and uBlock Origin -
https://linustechtips.com/topic/995485-adblock-plus-problem/#findComment-11974046
