Evening,
I5-8600K OC to 4.5
Case 570X ATX Mid-Tower
Mobo ROG Strix Z370-H
Problem: Been looking to move to the ROG RYUO 240 all in one liquid CPU cooler (2x 120mm) however the overall depth is 52mm and my case only allows for 50mm. I've tried everything I can think of without physically modding the case to make up the missing 2mm.
Question: Any ideas how to mod to move the items around to fit a liquid cooler with a total depth of 52mm? There are additional mounting locations but I have heart set on dual fan location on top of the case. And yes this purely a want situation.
https://linustechtips.com/topic/995466-water-cooling-space-issue/
I would just bend the tabs up top with my hands but thats me. Theres not much you can do and i would highly recommend not taking off the VRM heatsyncs. If it doesnt fit, then it doesnt fit unless you make it fit.
CPU:R9 3900x@4.5Ghz RAM:Vengeance Pro LPX @ 3200mhz MOBO:MSI Tomohawk B350 GPU:PNY GTX 1080 XLR8
DRIVES:500GB Samsung 970 Pro + Patriot Blast 480GB x2 + 12tb RAID10 NAS
MONITORS:Pixio PX329 32inch 1440p 165hz, LG 34UM68-p 1080p 75hz
take off the mobo heatsink and shave off a couple mm with a dremmel, it will not harm vrm performance
CPU: i7 8700K OC 5.0 gHz, Motherboard: Asus Maximus VIII Hero (Z170), RAM: 32gb Corsair Vengeance RGB 3200 mHz, GPU: Asus Strix OC gtx 1080ti, Storage: Samsung 950pro 500gb, samsung 860evo 500gb, 2x2Tb + 6Tb HDD,Case: Lian Li PC O11 dynamic, Cooling: Very custom loop.
CPU: i7 8700K, Motherboard Asus z390i, RAM:32gb g.skill RGB 3200, GPU: EVGA Gtx 1080ti SC Black, Storage: samsung 960evo 500gb, samsung 860evo 1tb (M.2) Case: lian li q37. Cooling: on the way to get watercooled (EKWB, HWlabs, Noctua, Barrow)
CPU: i7 9400F, Motherboard: Z170i pro gaming, RAM: 16gb Corsair Vengeance RGB 3200 mHz, GPU: Sapphire Vega56 pulse with Bykski waterblock, Storage: wd blue 500gb (windows) Samsung 860evo 500Gb (MacOS), PSU Corsair sf600 Case: Motif Monument aluminium replica, Cooling: Custom water cooling loop
  1. get a couple of 120 x 20 fans
  2. get 100mm fans and mount on 120mm adaptors
  3. drill new mounting holes with rad further from mb
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
