Angled SATA cables
Go to solution Solved by W-L,
On 11/15/2018 at 8:23 PM, Slayerking92 said:
Anyone know of any angled SATA cables that are stack-able?  One port would need to be slightly longer to go over the lower one.  (please excuse my ms paint skills)
Your best bet are slim line sata cables like the ones from silverstone.
https://www.silverstonetek.com/product.php?pid=445&area=en
Slayerking92
<Type something witty here>
<Link to some pcpartpicker fantasy build and claim as my own>
https://linustechtips.com/topic/995381-angled-sata-cables/
Why not just use an un-angled sata cable for the one that goes over the angled one?
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/995381-angled-sata-cables/#findComment-11970316
I need them to go straight down through the motherboard tray,  just wanted something that would look cleaner..
Slayerking92
https://linustechtips.com/topic/995381-angled-sata-cables/#findComment-11970320
Not sure what case you have but you rarely see the sata cable in the first place. At least in my s340 case.
https://linustechtips.com/topic/995381-angled-sata-cables/#findComment-11970327
What you can try is having the bottom one at 90 degree and the top on strait with a small loop that follow the first one into the MB
https://linustechtips.com/topic/995381-angled-sata-cables/#findComment-11970379
https://www.silverstonetek.com/product.php?pid=445&amp;area=en
https://linustechtips.com/topic/995381-angled-sata-cables/#findComment-11974050
Akasa Proslim SATA cables have short connector bodies and thin cables that take tight bends well. These cables have the added advantage that they can be shortened.
Jeannie
As long as anyone is oppressed, no one will be safe and free.
One has to be proactive, not reactive, to ensure the safety of one's data so backup your data! And RAID is NOT a backup!
https://linustechtips.com/topic/995381-angled-sata-cables/#findComment-11974465
Those will definitely will work for me.  It looks like they can bend straight down without an issue.  Thank you.
Slayerking92
https://linustechtips.com/topic/995381-angled-sata-cables/#findComment-11976133
