Making decision for CPU
Go to solution Solved by Princess Luna,
22 minutes ago, ShadowSlayer said:
Cpu's i have in my:
1. Intel i7-7700k, no need for new motherboard
2. Intel i7-8700k- would need a new motherboard
3. Ryzen 7 2700x- would need a new motherboard.
1. Can you close your side applications, background junk and all to go game? like can your OS be clean and let it focus resources on the game instead of w/e else? If you can do that this processor satisfies the 1070 Ti for high refresh rate in all accounts and will be much the same of at least lets say a stock i5 8600K.
2. You are doing this for higher refresh rate and the i7 8700K is the to go chip for that as it's identical to the i7 9700K on this regard. You will be by all means eliminating any bottleneck chance to the 1070 Ti... or a 1080 Ti... RTX 2080 Ti? You see it's really the best and you might be misjudging how much your 1070 Ti requires. Do this if you have the money as think it as a luxury.
This CPU however can be justified if you want to leave a bunch of junk open alongside your game like 200 tabs in chrome yay, content creation blah blah bah
3. This is the CPU you pick if you'll actually do *serious* work, since it prioritizes that at much better price while it can game all the same albeit bit lower fps... you know it's the people who aren't in this for a luxury alone for them, and the whole idea of price to performance rises up.
Awesome pick, AMD brought performance cost so much lower it should always be praised my brother was saving for an i7 6900K he managed to build an entire 1800X build for cheaper than the CPU price for an on pair performance lel.
The way I see it you should just get the i7 7700K, it's basically the i7 8700K with 2 cores less and lil bit less cache, so "IPC OC" and w/e is really much the same and its single thread performance which Still is the most important thing on gaming is on pair with the top.
Hello everyone, i hope i won't be bothering anyone.
I'm in need for some more experienced PC builder advice, so i'm turning to LTT Forum community.
After upgrading my monitor to 144hz i found a possible bottleneck whitch could be my CPU. After some thought i have 3 CPU's in mind. I will be mostly gaming on my PC and from time to time editing some videos.
Cpu's i have in my:
As Black friday and Christmas time is coming closer prices for some computer parts gonna drop, so i hope to find some good deals along the way.
My system specs:
Intel i5-7400
Asus Prime Z270-P
Corsair 12Gb DDR4 2400mhz (4gb+8gb)
Asus GTX 1070ti
Kingston 120gb SSD
Seagate BArracuda 2TB Hard drive
Corsair CP-9020078-UK Builder Series 750W Power supply
Asus VG248QE Display
Thanks in advance.
Cheers.
https://linustechtips.com/topic/994113-making-decision-for-cpu/
1. depends on how much you can spend
2. 7700k is usually expensive used for some reason, that's why it's so difficult to recommend.
Desktop benching:
https://linustechtips.com/topic/994113-making-decision-for-cpu/#findComment-11958811
Sorry, i forgot to mention how much i can spend. My upper limit is aroung 500 GBP
https://linustechtips.com/topic/994113-making-decision-for-cpu/#findComment-11958816
then it's 8700k for sure. It will stay relevant much longer than the 7700k (which is already showing its age) and can hit high frame rates regularly compared to the 2700X (or any Ryzen CPUs we've seen atm)
Desktop benching:
https://linustechtips.com/topic/994113-making-decision-for-cpu/#findComment-11958846
Would i need a z370 motherboard with the 8700k or z270 would still be ok?
https://linustechtips.com/topic/994113-making-decision-for-cpu/#findComment-11958858
You will need a Z370 mobo or else it won't boot. For overclocking, a good one is crucial.
Desktop benching:
https://linustechtips.com/topic/994113-making-decision-for-cpu/#findComment-11958864
You could, if wanted get an i7-8086k for that price which is the fastest i7 CPU of all time: https://www.amazon.co.uk/Intel-Core-8086K-4-0GHz-LGA1151-x/dp/B07DGDWJ3P
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/994113-making-decision-for-cpu/#findComment-11958870
Thanks for the advice. I'll se what i can get around christmas time :)
Wow, that CPU is hella fast. But at the same time it's hitting end of my budget. Knowing that i probalby would need to spend around 150 GBP on motherboard. So it's kinda out of reach. And buying 8086k wound mean that i need to upgrade to 1080 or something simmilar.
https://linustechtips.com/topic/994113-making-decision-for-cpu/#findComment-11958895
you don't have to, you just dont get everything of the 8086k out. However, even 2080ti can't do that all the time at 1080p
Desktop benching:
https://linustechtips.com/topic/994113-making-decision-for-cpu/#findComment-11958904
Cpu's i have in my:
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/994113-making-decision-for-cpu/#findComment-11958907
Thank you for the time you spent typing that down. It was detalized and with a little bit of humour. In all seriousness it all comes down to to the price. Like everyone else i too want to have prices as low as possoble. At the moment price difference between 7700k and 8700k is around 60 gbp.
My housemate has 7700k bought last christmas for 270 gbp. So i hope something simmilar will happen this year.
If i can bring that price difference low enough i might try my luck for 8700k, but if not then 7700k will have to suffice. You know at christmas you always spend way too much money on thing you might not need. And in next year you go complaining that you ran out of money :P
https://linustechtips.com/topic/994113-making-decision-for-cpu/#findComment-11958942
With that money I would also get more than a CPU and mobo.
PCPartPicker part list: https://uk.pcpartpicker.com/list/FBgfGG
Price breakdown by merchant: https://uk.pcpartpicker.com/list/FBgfGG/by_merchant/
CPU: AMD - Ryzen 7 1800X 3.6 GHz 8-Core Processor  (£210.77 @ CCL Computers)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  (£79.19 @ Amazon UK)
Memory: Corsair - Vengeance RGB 16 GB (2 x 8 GB) DDR4-3000 Memory  (£131.99 @ Aria PC)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive  (£75.16 @ Amazon UK)
Total: £497.11
Generated by PCPartPicker 2018-11-13 00:20 GMT+0000
https://linustechtips.com/topic/994113-making-decision-for-cpu/#findComment-11958971
