Hi guys
My components are
Corsair obsidian 500d
Gigabyte z390 aorus master
Evga g2 gold 650w supernova
Samsung 970 pro 512gb
2400mhz 2x16 15-15-15-35 ripjaws v
Evga clc 280
My Temps are...... The same. Should I delid again and apply more conductonaut?
Oops, my cpu is an 8700k and I also have a rog strix 1080 ti oc
https://linustechtips.com/topic/993698-conductonaut-made-no-difference/
What are your temps and what cooler are you using?
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
Did you reseal?
Primary PC:
PSU tier list
How many watts do I need?
did you apply conductonaut to the CPU DIE and IHS? if not try that.
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
  • 2 weeks later...
3 minutes ago, Virtualnate said:
I'm sitting at 32c at idle just like before, I'm using an evga clc 280, should I go for a custom loop?
Your Idle temps isn't what should change! It should only really affect your maximum temps. So please tell me you ran a stress before delid and recorded that temp along with the ambient temp, then that you ran it again after delid recording the max temp of your cpu and the ambient again.
If so THOSE are the numbers we need.
