Stuck between mobile GPUs
Go to solution Solved by Enderman,
38 minutes ago, er4di said:
Well, the others specs are just fine, as far as i compared. the MSI pulls abit ahead for me.
Just to clarify my question, will a 1060 be noticeable quiter then a 1070 ?
Not really, you can always lock the fps and the 1070 won't work as hard and will also be quiet.
Hey Guys,
with Black Friday at it's door I plan to get a new Notebook.
While researching I got stuck between the choice mobile 1060 vs mobile 1070 (both paired with a i7-8750H, Manufacturer MSi GE73 and Asus GL703, maybe Acer has something familiar).
My main usage is playing World of Warcraft and several MOBAs (everything in 1080p@60/120hz).
I would sacrifice some frames for a lower noise level.
Can you share your opinion about this and maybe give me an advice?
https://linustechtips.com/topic/993483-stuck-between-mobile-gpus/
Both will perform great and you should look at the other important specs of the laptops such as size, weight, documented issues, customer support, etc.
