DC power supply, is it a good choice?
3 minutes ago, Islam Ghunym said:Ah I think you didn't notice that I wanted to buy a DC input PSU which I think it will last longer, so is it a good idea or wont be much effective way and wont make real differnce?
In theory battery provides slightly less amperage meaning less Ghz for CPU/GPU/RAM, I have also crazy ideas to turn my desktop pc into portable pc, but issue was to recharge batterys while I working with my pc I had to turn off pc, disconnect battery charge it and connect back to pc, why I didnt charge while I was using pc? because charger provides to much amperage(~55 if I remeber), me personal advice buy bigger ups so it could last longer. If you dont need so portable pc just only maintain stable power you could use car battery, install amperage controller which should output around ~35A, If I were you take diesel car battery they bigger and will last longer. Good luck.
