Driver for 'driverless' USB headphones?
Solved by Brennan Price,
The headphones you mention are indeed USB and do need drivers however if you go into device manager and uninstall all audio drivers there, you can then install the Logitech ones and they should then work. If you get further issues then I would recommend using Realtek HD audio drivers instead.
Featured Topics
atxcyclist ·
Posted in Home Theater Equipment0 -
3
ElChales ·
Posted in New Builds and Planning4 -
Gundmi ·
Posted in Troubleshooting0 -
ElChales ·
naldo29 ·
Posted in Troubleshooting2
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
