Gigabyte GTX 1080 G1 RGB issue
5 hours ago, Feral_Ghoul said:I got this card a couple of days ago, I noticed that the lights on my GPU are still orange when the PC boots up and the AORUS GRAPHICS ENGINE software launches. I have constant orange light just refuses to change the colors because its blank in the software. I have tried everything, fully uninstalled the gigabyte software and reinstalled it, removed the GPU and put it back, turned the pc off multiple times and even used Display Driver Uninstaller. But the rgb has the waiing thing then its blank on the software. When I have updated to the new Aorus engine my fan on/off does not work but it works on my cd and the older update. The only thing that removes the orange is to uninstall the rgb then I does the random color thing for example green,blue and etc. The thing is the software wants to reinstall the rgb software then it goes back to orange.
Has anybody got any ideas on how I can fix this?
I got it finally after a few days of having this card
1) install new Nvidia drivers from there website
2) install xtreme engine
thats if you have a new computer
here is if your installing a new graphics card on windows 10
1) Download and Install DDU(Display Driver Uninstaller) I did a clean and shutdown
2) Make sure that aorus engine is gone. If it did not get it and there RGB in your control panel under uninstall, then restart.
3) Install new Nvidia drivers from there website
4) Install xtreme engine, I tried to get aorus to work all I got was on/off on fans to work.
Also with the lights for example it going green, blue and etc on the card if you do not see fan stop doing that when you have xtreme engine its working.
Another thing too is just removing aorus and there RGB. Then installing xtreme engine does not work you will be stuck on the same color but fan stop will be gone and you can control the fans in xtreme engine but not the colors.
I hope this helps.
