Dual tower air ccolers for my 8600K
Max Cheung
I have this plan for building a new PC. However, I don't know which cooler I should buy. Liquid cooling is out of the question. Custom loops are too cumbersome, and any cooling method that requires me to open the top of my R6 or sacrifice my front intake is not my cup of tea. I've been looking into dual tower air coolers and would like your recommendations for them. Of course, the best is have it to fit my black/white colour scheme.
TIA
Case and RAM, please. Those two dictate which coolers you can even use. Cryorig R1 Ultimate is probably the biggest, Dark Rock Pro 4 at the moment best overall.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I have had good results with a Noctua D15 on 8086k (5.1 all core without delid), and for stock it is overkill. Maybe consider the D14 also. Both should fit in the R6 and the cutouts are fairly high so most ram should still fit.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
What ram are you using? Where are you shopping / located? Budget?
