Egpu or monitor
Solved by BrinkGG,
13 minutes ago, experiencednoob said:Yeahh..about that, I can’t find a 120hz screen replacement here in the Philippines...would the 1050ti still be a good gpu for at least 3-5 years?
There's no way of telling. Graphics have made a LOT of improvements over the past few years. Look back at how irrelevant a GTX 750 Ti or GTX 660 is for high end gaming.
Also, I meant get a second 144 hz display instead of upgrading the internal display.
Something like an Asus VG248QE or similar 24 inch 144hz monitor is usually around $200 USD.
