I'm looking for a soild built small/portable case that can hold a gtx 1080ti and 2 additional pcie express slots it's going to be moved around a lot so I'd prefer it not have glass sides and a handle would be preferable I'd like a case that's pretty small but obviously not a tiny console sized PC. Thx?
https://linustechtips.com/topic/989114-micro-atx-case/
Any specific reason you're going with a mATX build, I don't recommend it unless you have limited space.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/989114-micro-atx-case/#findComment-11912808
Because it is the so much better form factor that will not die on my watch.
Any ways what makes this difficulty is the lack of side glass panel, mATX or not, nowadays high end cases will always have the side glass panel it's pretty standard... the ones without it are usually cheap and crap.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/989114-micro-atx-case/#findComment-11912815
Personal Desktop":
https://linustechtips.com/topic/989114-micro-atx-case/#findComment-11912821
I don't understand what you're saying
https://linustechtips.com/topic/989114-micro-atx-case/#findComment-11912823
What makes mATX bad? My main system is mATX and it looks beautiful and performs great within expectation for the hardware, it is more compact and simply fits better the desk.
So I'm intrigue what urges you to say mATX is bad instead of just helping him out find a case.
Personal Desktop":
https://linustechtips.com/topic/989114-micro-atx-case/#findComment-11912831
I never said it's bad, even my case is a mATX tower.
https://linustechtips.com/topic/989114-micro-atx-case/#findComment-11912850
http://www.sliger.com/products/cases/cerberus/
https://linustechtips.com/topic/989114-micro-atx-case/#findComment-11914615
