I need help choosing a new CPU for my computer, I'm a bit new to upgrading computers and I'd like help finding a good budget CPU for running modern games.
My motherboard is a GIGABYTE GA-F2A68HM-H with a FM2+ socket
if its relevant my GPU is a Radeon RX 580
and I have 2 8GB sticks of DDR3 ram.
My current CPU is a AMD A4-6300 APU
My budget is around $90-$110
Let me know if you need anymore information and thank you for the help.
Edit: getting a new MOBO is kind of not an option... what would work best for what I have right now?
https://linustechtips.com/topic/989056-help-with-choosing-cpu/
It’s probably best you buy a whole new cpu/MoBo and maybe ram. What is your budget and location?
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/989056-help-with-choosing-cpu/#findComment-11912161
What's your budget? You'll want an R5 1600/2600 to go with that RX580 IMO.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/989056-help-with-choosing-cpu/#findComment-11912162
The best bet would be to switch platforms. The 580 is a very good card and I would imagine your current cpu is holding it back. I would suggest moving to ryzen as they are the best for budget cpu upgrades and are on a platform with alot of support. What is your budget for the upgrade?
https://linustechtips.com/topic/989056-help-with-choosing-cpu/#findComment-11912164
Your CPU is absolutely holding you back.  That MOBO is an FM2+ socket only from what I am reading so until you upgrade as described above (new mobo, CPU, RAM if you go current Gen) you are stuck basically (with NO reason to get a better APU for your FM2+ socket).
What is your budget OP?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/989056-help-with-choosing-cpu/#findComment-11912188
FX 8350 off eBay and a good CPU cooler would be the cheapest recommendation I could think of, but it's not a particularly good platform. FX is power hungry, old, and slow. A used Ryzen CPU offers great performance per dollar if you're willing to save up and buy off eBay.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/989056-help-with-choosing-cpu/#findComment-11912197
Negative! An FX series CPU will not work with the FM2+ Socket and chipset! OP would have to switch to AM3 or AM3+ depending on the model of FX CPU he gets.
I suggest saving (if budgeted) and going for Ryzen. The performance increase will be well worth the (relatively little) extra money. That results in a New MOBO with the AM4 socket, the Ryzen CPU of your choice, recommended ryzen 5 2600, and DDR4 RAM of your preferred amount.
https://linustechtips.com/topic/989056-help-with-choosing-cpu/#findComment-11912227
Oops
Primary PC:
PSU tier list
https://linustechtips.com/topic/989056-help-with-choosing-cpu/#findComment-11912274
I am new to this and I am open to the idea of saving but my current budget is around $90-$120
And if by location you mean my country I'm USA
https://linustechtips.com/topic/989056-help-with-choosing-cpu/#findComment-11912275
You can probably find a used Ryzen 3/MoBo/ram combo for... well it might be closer to $150 or so... hm. Maybe a used i5-3570(k) or i5-4670(k)/4690(k)?
https://linustechtips.com/topic/989056-help-with-choosing-cpu/#findComment-11912371
