idle, windows / load
RX Vega64 = 20W/295W
RX Vega56 = 16W/255W
RX580 = 16W/225W
RX570 = 16W/175W
RX560 = 9W/79W
RX550 = 7W/45W
RX480 = 16W/164W
RX470 = 16W/144W
RX460 = 13W/110W
RTX 2080Ti = 17W/260W (FE)
RTX 2080 = 15W/225W (FE)
RTX 2070 = 15W/185W (FE)
GTX1080Ti = 13W/245W
GTX1080 = 6W/184W
GTX1070Ti = 6W/175W
GTX1070 = 6W/151W
GTX1060 = 6W/122W
GTX1050Ti = 6W/75W
GTX1050 = 6W/75W
There's some asian only cards like gt 1050 with 3 GB of memory (96bit) or RX 570 with fewer shader units, these aren't in the list above but it's give or take 10-20w.
https://linustechtips.com/topic/988827-power-consumption/#findComment-11909688
17 hours ago, Mholes said:
Well unless you have a <=400W power supply there should be no problem. Since Nvidia recommends a 400W for GTX1060 and AMD recommends a 500W for the RX580.
Those are RECOMMENDATION tho.
So like @GoldenLag said pick the cheaper one.
Ok i think i'm gonna pick RX 580,
Thanks bro
https://linustechtips.com/topic/988827-power-consumption/#findComment-11913310
RX580 = 16W/225W
RX570 = 16W/175W
RX560 = 9W/79W
RX550 = 7W/45W
RX480 = 16W/164W
RX470 = 16W/144W
RX460 = 13W/110W
GTX1080 = 6W/184W
GTX1070Ti = 6W/175W
GTX1070 = 6W/151W
GTX1060 = 6W/122W
GTX1050Ti = 6W/75W
GTX1050 = 6W/75W
1080 have lower consumption more than rx 580? Wow i dont know it since you give me this lol
https://linustechtips.com/topic/988827-power-consumption/#findComment-11913315
