Strange Question
Go to solution Solved by RollinLower,
definitely possible, there's even a WikiHow article about this:
https://www.wikihow.com/Cut-the-Number-Pad-off-a-Keyboard
If you're aiming for TKL, that's not half the keyboard...
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/988617-strange-question/#findComment-11907262
2 minutes ago, RandomGu123 said:
Ok, This may seem strange but its for a science project xD
Its not really for me, just my curiosity.
Do you guys think you could saw, or just break a membrane keyboard in half and still have it work?
Like a DIY Tenkeyless keyboard?
Told you its weird
Actually that is a funny/potentially plausible question XD
I am going to hazard a guess and say no, you'll likely tear an important trace on that sheet that sits below the membrane but I can't provide evidence since no one has probably ever asked
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/988617-strange-question/#findComment-11907272
I mean I have a spare $7 keyboard lying around, maybe one day ill try it xD
https://linustechtips.com/topic/988617-strange-question/#findComment-11907281
You could maybe ask GamersNexus (Who do a lot of very technical computer related stuff videos) using there #AskGN, and you might be featured in a video
https://twitter.com/hashtag/askgn
https://www.youtube.com/user/GamersNexus
Good luck!
https://linustechtips.com/topic/988617-strange-question/#findComment-11907290
Good luck!
https://linustechtips.com/topic/988617-strange-question/#findComment-11907297
https://linustechtips.com/topic/988617-strange-question/#findComment-11907323
