Hi! I am just picking some parts for my builds and i came across a problem. I live in Singapore and the plugs in my house probably have a different voltage than what the power supply needs. An adapter will also not change the voltage. Is there any item that can change the voltage or should i just buy a power supply in Singapore? (Sorry im quite new to pc building. Btw this is my first time building a pc)
https://linustechtips.com/topic/987759-power-supply-question/
You could check the ratings on the psu, because most decent modern electronics nowadays that hook into mains power are made to work anywhere between 120V and 240V at both 50hz and 60hz, so it would be very likely you just need to get a power cable that is compatible with the Singapore outlets physically, although remember to actually check first if the psu will work with it all.
Sadness is the one true emotion, and happiness, well, that's just a lie, sadness is all many of us feel, and is all we need to feel, because having it any other way, would just be wrong, why be happy when you can just be miserable like myself.
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11899028
Well, what voltage does your wall output?
It's probably either 240 or 115V.
Also,every psu you can buy in Singapore will be compatible because it would be stupid if it wasn't.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11899029
Hi im not sure if im supposed to post here but my computer has a 700watt ezcool silent psu the specs are an amd a6-6400k duel core 3.9ghz cpu, 6gb ram, windows 10 64 bit and a xfx amd radeon r7970 ghost edition 3gb gnu but it keeps shutting itself down when I try doing a bench mark on car mechanic simulator on medium, shuts down on tera and on killing floor 2 but its fine with left 4 dead 2 what could be wrong ive changed the voltage the ram gets in the bios from 1.5 to 1.65 and ive changed the MHz they do from 1333mhx to 1800mhz to see if it works and its fine on Stardew valley since its a 2d game but other than that it shuts itself down can someone help or advise me please (p.s at the moment I have a financial problem so saving up for a new part is an issue).
Thanks Chris
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11900214
You should live in a 220V AC/50Hz area.
That is the best for PSU there is. So there isn't a problem there.
...irrelevant as that PSU is garbage and to be replaced.
You don't need something fancy, an entry level unit with independant voltage regulation is more than sufficient.
So something like be quiet System Power (U)9...
But I'd not use that PSU as its a very low quality PSU in this category:
https://www.theregister.co.uk/2012/11/26/exploding_computer_vs_reg_reader/
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11902412
So system power u9 is a good psu, I've seen them in some places in latinoamerica it works with 100-120V AC right?
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11902447
No, it is an OK one.
Good would be the Straight Power 11 or Bitfenix Formula.
Quote
Yes, that's why they needed a new one with a different plattform.
The U9 is the 100-240VAC version the normal 9 is the 200-240VAC one.
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11902461
Oh I didn't know that
well yes it depends on your definition on good, I'm surprised to have forgotten than
but there's no straight power 11 or bitfenix formula in here
You only find: cooler master, corsair, evga, seasonic for the most part. And the cheap system power U9 in some places
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11902468
14 minutes ago, GHSTlordlambert said:
never showed me
~9h ago, with other stuff..
here what I said:
Quote
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11904167
here what I said:
fair enough so at the moment I can't turn my computer on then because the psu is garbage then im looking into an evga 750watt psu thats semi modular and a corsair 750watt psu which is all in one
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11904174
You do not need that high wattage, a good 400-550W is more than enough and probably cheaper, if available.
What are the ones available?
Because somethings like a 150HP BMW says nothing either...
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11904206
not sure whats available but the lowest that the gp can handle is a 550 but recommended a 650 so I though that because I have also been looking into a new cpu aswell which for that I found a amd a8 quad core thats fa superior to mine at CEX for £20.00 I can have a look at pc world/ currys as thats our pc shop and id prefer to buy it from a shop than an online one
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11904232
If you're on a budget, its rather unlikely that you will be able to get close to even 500W.
A Ryzen 7/1700X with _TWO_ Radeon HD7970GHz/280X is around 550W load.
So that means you need a highest end GPU with high end CPUs to get close to that...
So that means a PC in the direction of 2000€.
Do you have the money or want to spend it?
For ~1400€, you're fine with 400-450W.
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11904302
I don't have the money at the moment but hopefully I will soon and ah fair enough I get you and I built this pc on a budget last year in total it cost me £250 and adding the new gpu is around £310 but I was also think gin a 750 just incase I wanted to upgrade in years to come but I can go lower because if it will save money
https://www.pcworld.co.uk/gbuk/computing-accessories/components-and-upgrades/power-supplies/1113_8408_71555_xx_xx/1_16/price-asc/xx-criteria.html
these are what I can try to get
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11904423
What about 240V? Just making sure because im a first time builder and don’t wanna waste my saving from the whole year.
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11906401
-snip-
Sounds like you should create your own topic instead of commenting on someone else's. Do you know how?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11906467
I told him the same thing last night in another topic LOL
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11906587
Oy vey
Primary PC:
PSU tier list
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11906590
240VAC is the upper end of the PSU input voltage.
So no problem there, most are specified to allow that.
https://linustechtips.com/topic/987759-power-supply-question/#findComment-11906650
