Wireless mouse & wired keyboard recommendations
G'day
I currently own a Logitech G910 and it's absolute garbage. (out of warranty period now).
Also have a wired MadCatz mouse that plays up occasionally.
So I've been seeing that apparently wireless mouse's have gotten pretty good and that you can get mouse pads that wirelessly charge them.
Only problem is the only two options I can find are Logitech (who I don't want to go with after this abomination that is the G910), and Razer.....which is well Razer.
So if anyone can recommend a wired keyboard with wrist rest, wireless mouse with charging mouse pad (all the same brand preferably) I'm all ears.
Cheers.
Logitech G903/703 + Powerplay Mousepad  (very pricey), I've been using the G903 for a few years now, absolutely love it and adding PowerPlay is just brilliant!
As for keyboard, honestly its personal preference with key switches (I agree G910 is trash, keycaps + switches aren't for me).
However I do recommend Logitech G710+ (Brown/Blue switches) it just has everything you need - 1 row of G keys - media control - white led backlighting - detachable wrist rest!
CPU: Intel i7-3770k (@4.4Ghz) Mobo: Asus Maximus V Gene Z77 RAM: 16GB DDR3 Corsair Vengence SSD:120GB Samsung EVO & 128GB Crucial M4 (Fast Storage) Storage: Hitach 3TB HDD GPU: Powercolor R9 290 PCS+ CPU Block: EK Supremacy Gold Clean CSQ Radiatiors: Alphacool NexXxoS Full Copper XT45 120mm, ST30 280mm & XT45 280mm w/ 140mm Phanteks PWM PSU: Corsair HX-650w Gold Soundcard: Asus Xense Case: Corsair Carbide A540 (Black & Gold) Front Panel: NZXT Hue & BitFenix Hydra Pro Speakers: Swan M200MKIII HeadsetSennheiser PC350 (Xense Edition)
A good keyboard I can recommend would be the Leopold FC750r and the Leopold FC900r, they have great build quality, and they have doubleshot pbt keycaps which are very durable. The only downside is there is no dedicated media functions and rgb. And for the wrist rest you can just buy any tkl wrist rest from elitekeyboards or amazon.
