Running Xbox and PC audio on the same speakers
On 10/27/2018 at 4:27 AM, Tore Alkeks said:Yes it works.
Sorry took a sec to get back to you, all you need is a basic mixer and 3x3.5mm to RCA cables:
https://www.amazon.com/Rolls-MX42-Stereo-Mini-Mixer/dp/B00102ZN40?crid=R8Z4RAGGM8WW&keywords=stereo+mixer&qid=1540830918&s=Musical+Instruments&sprefix=stereo+mixer%2Cmi%2C186&sr=1-7&ref=sr_1_7
https://www.amazon.com/UGREEN-3-5mm-Auxiliary-Stereo-Splitter/dp/B00LM2Y2U4?keywords=3.5mm+to+rca&qid=1540831039&s=Musical+Instruments&sr=1-7&ref=sr_1_7
Your on-board audio into one input, the display audio into another input and the output to the speakers.
If the 3.5mm cable attached to your speakers isn't modular you will need female 3.5mm to RCA:
https://www.amazon.com/UGREEN-Adapter-Smartphones-Tablets-Theater/dp/B00QUWDUMC?keywords=female+3.5mm+to+rca&qid=1540831276&s=Electronics&sr=1-6&ref=sr_1_6
