My dad has bought a printer. He needs a serial port cable for it. These are the specifications. Where might I be able to buy one. Thanks in advance
https://support.hp.com/us-en/document/bpp03782#AbT14
There are 10 types of people in the world. Those that understand binary and those that don't.
https://linustechtips.com/topic/986388-help-with-printer-serial-cable/
Did he stumble into 1990 and buy a printer?
Ebay or another used site is going to be your best bet these days.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
The problem is that I don't know what cable it needs, as it seems to be a proprietary cable that doesn't have a name
Okay first things first... You do realize your dad bought a plotter? These things are like industrial grade printers that consumers shouldn't really be using.
Otherwise it looks like you're supposed to hook this up to a network or, in a pinch, use a IEEE-1284 cable.
I did know, he's starting a design and craft kinda company, like printing posters he makes and stuff, and basically, the drivers for the network port were only updated for versions lower than what his mac is on, so he can't use the network port with it, he has to use the serial port, and if you look in the link i put in the first op, it states that most cables follow a standard, but this one does not.
