Hello, iam building a new system and i need a gpu, There is so many different 2080ti cards to choose from.
System iam building:
cpu: i9-9900k
750w psu
3200hz ram
970evo m2.
I dont like to overclock gpu and want a good 2080ti right out of the box, which should i buy?
Thanks
https://linustechtips.com/topic/986219-rtx-2080ti-help/
Asus Strix is always a good bet, and so are EVGA's ACX/ICX cards.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/986219-rtx-2080ti-help/#findComment-11884194
@Spillgal
What monitor do u have ?
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/986219-rtx-2080ti-help/#findComment-11884224
Ah ok, so yea if u got the cash to throw at it a 2080ti would be good.
in all honesty, just grab any of them, the cheapest u can find. They will all perform roughly the same. perhaps base it on the asthetics if your building around a theme.
https://linustechtips.com/topic/986219-rtx-2080ti-help/#findComment-11884250
I am on auto notify for a EVGA GeForce RTX 2080 Ti XC ULTRA. Since the clocks are slightly higher than the non ultra it may be binned. If I was thinking of doing SLI with the card I would get the non ultra.
To me this a interim card. I am only planning on buying one. When I bought my first GTX 1080 ti I went with a 2 slot version because at some point I planned to get another one and do SLI. When I get the RTX 2080 ti my other computer will have GTX 1080 tis in SLI.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/986219-rtx-2080ti-help/#findComment-11884576
1 hour ago, Spillgal said:
What about RoG Strix oc ?
Strix cards are top tier. If you want high performance out of box, Asus is the go to IMO
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/986219-rtx-2080ti-help/#findComment-11886069
