Loud noise
Go to solution Solved by Kayn,
If it's not your GPU then it might be your CPU cooler.
I didn't know if I should post this in GPU or Troubleshooting.
I recently bought a R9 270, I love it and does what I want it to do well however it makes a lot of noise. I have been monitoring it with MSI Afterburner. It runs at about 50-55 degrees celsius while gaming however the fan speed and RPM graphs do not go up but the cards noise does. I just want to double check everything is fine.
CPU: Phenom 1090T, Motherboard: Gigabyte 78LMT-USB3 RAM: Generic 8GB 1600MHz GPU: MSI Radeon R9 270 HDDs: 2 Scavenged 160GB drives (I lost my 500GB one and I don't know how) SSD: Samsung 840 evo120GB  OS: Windows 7 Case: Bitfenix merc beta PSU: Corsair CX 600W
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
I am running a stock one it could be, I will do a little test and report back
maybe you just got a faulty product maybe ring up amd see what they can do then try and RMA it, but some people say these are noisy cards others say there silent so.
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
Id attribute it to your cpu fan. Those things can get loud under load.
| Corsair Carbide Series 350D |Corsair H100i | Intel i7 5820k @ 4.5GHz, 1.175v | EVGA x99 Micro 2 | G.Skill Trident Z 32gb, 3200MHz
| Gigabyte G1 Gaming 980Ti @1506MHz | EVGA P2 850 Watt | 2x Samsung 850 Evo 500gb | Western Digital Red Pro 6TB |
Well I don't think it is my CPU as I get a temp rise of about 14 degrees. I think MSI afterburner is just wrong. It only happens when I game also. I don't think I need to RMA it, I think it is just a bit loud
You were correct, MSI afterburner wouldn't tell me but Liam-McShane kindly recommended me CPUID and yep it is the stock cooler fan
You were correct, MSI afterburner wouldn't tell me but someone kindly recommended me CPUID and yep it is the stock cooler fan
Yeah those AMD stock CPU coolers really ramp up hard on the fan curve, its quiet until you do anything. but since you can get good aftermarket coolers for £20ish.
AMD Ryzen 5900x, Nvidia RTX 3080 (MSI Gaming X-trio), ASrock X570 Extreme4, 32GB Corsair Vengeance RGB @ 3200mhz CL16, Corsair MP600 1TB, Intel 660P 1TB, Corsair HX1000, Corsair 680x, Corsair H100i Platinum
This is my next plan
