Hi there,
I need help because this problem is driving me crazy.
This began right when I purchased GTX1080. When I have nvidia drivers installed, my entire PC has  microstuttering/rubber banding. I can tell that even by moving mouse cursor  along my desktop. It move with somewhat slight but very noticeable stutters as if my refresh rate was 30HZ, in games its even worse because they run as if they were locked to 30FPS.  If I uninstall GPU drivers, those stutters go away, I can tell that my mouse cursor is very smooth and seamless.
My FPS are fine, same as monitor refresh rate (75Hz). I don't know what is causing it. Previous I had driver 411.70 that was running perfectly fine, but yesterday for some dumb reason I updated to 416.34 and problem returned. the sad part it that I've tried rolling back to 411.70 and a handful of other drivers, but this issue doesn't go away. Also, its not GPU problem. I've tried 3 different GPUs, all of them have this issue.
My theory could be that my previous RX480 could've damaged by motherboard when it died. But then again, why is everything working perfectly when no drivers are installed.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
51 minutes ago, PopsicleHustler said:
Hi there,
Did you use DDU to uninstall the previous drivers?  Display Driver Uninstaller Download version 17.0.7.8
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Yes
2 minutes ago, PopsicleHustler said:
Yes
Hmm, in that case if it's that annoying I would most likely just reinstall windows to try and get rid if the problem.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
