To capture your desktop, windows aero needs to be activated.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/98366-problems-with-fraps/#findComment-1316267
Have you enabled "Monitor Aero Desktop(DWM)"... It's in the general tab
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/98366-problems-with-fraps/#findComment-1316269
Fraps is made for gameplay not screen recording camtasia would be better suited to this
Oh no, clearly FRAPs can't record desktop....
https://linustechtips.com/topic/98366-problems-with-fraps/#findComment-1316274
I use Open Broadcaster Software to record my gameplay or whatever.
It's meant for streaming, but it can record your desktop or wtv too.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/98366-problems-with-fraps/#findComment-1316286
