3D Build - Are there any issues?
Solved by Jurrunio,
GPU is very overkill. Even if you overclock the CPU it's still totally unbalanced for 1440p ultra.
If you want raytracing though that's too harsh. 2080ti is known to do raytracing accpetably only on 1080p, no hope on 1440p.
Seosamh_101 ·
Posted in Windows1 -
1
1
2
3
ShayOh ·
Posted in Troubleshooting2
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
