FAH web control not loading
Go to solution Solved by porina,
Rebooting doesn't help, and neither did turning off adblock on browser just in case that was interfering in some way.
I just tried Edge, and that worked 1st time. So there is something about Chrome... I don't have any plugins other than ublock origin, and that was disabled for test.
I just installed FAH onto one system (6600k, 1070). Install went ok, retrieved my passkey, entered LTT team, and away it went. I had stats in the web view, and of most interest was that the CPU was estimating around 1/1000 the PPD of the GPU, so that's not going to continue after the existing unit runs. That's after increasing it to use 3/4 cores.
I left it for a while, and wanted to see if anything had changed. Now when I try to open the web interface, it constantly refreshes without showing any of my data. In the bottom of Chrome I see "waiting for 127.0.0.1". Any ideas?
https://linustechtips.com/topic/983449-fah-web-control-not-loading/
I know it seems obvious but have you tried rebooting?
Hm, well that's good you at least have a workaround in the mean time.  I doubt it's some inherent incompatibility with Chrome given how common of a browser it is.  Perhaps something specifically with your install of it is causing a problem?  It wouldn't be the first time that's happened with some site that I've seen.
I'll have another poke at it later. It was crunching the whole time anyway. Think I saw somewhere that firewall rules could cause funny things so I could check that.
I get this exact issue with chrome myself. I just use the advanced during the first place because I control two machines from the one interface, that way I don't have to go to the spare room to check on it all the time.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
I also use the F @ H Mobile monitor app on my iPad. It’s a little buggy but it allows me to view the progress and pause and finish slots and look at the logs from the couch.
6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Asus ProArt x670e WiFi; Ryzen 9 7950x; EVGA 240 CLC; 2 x 48GB DDR5-6000; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 2 x 8TB NAS; MSI RTX 4070 ti Super; AMD FirePro W4100; Corsair SFF750
nas1: Fractal Node 804; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB Samsung EVO Pro SSD; 7 x 4TB Seagate NAS; Corsair HX650i
nas2: Synology DS-123j; 2 x 6TB WD Red Plus NAS
nas3: Synology DS-224+; 2 x 12TB Seagate NAS
dcn01: Fractal Pop Silent XL; Gigabyte Aorus z570 Master; Ryzen 9 3950x; AMD Wraith; 2 x 16GB DDR4-3200; 256GB NVMe; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Gaming X; Corsair RM750e
dcn04: Fractal Define S; Gigabyte Aorus ax570 Master; Ryzen 9 5950x; BeQuiet! PureRock 2; 2 x 16GB DDR4-3200; 250GB NVMe; ; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Ventus 2; Corsair TX750M
