So I am apparently really bad at picking pc parts so I need at bit of help. If some one can put a part list together for me that would be great.
I do have a few guidelines to follow though:
  1. Under $1000 USD
  2. Can run most games in 60FPS @ 1440p
  3. Can stream with the rig
  4. At least a GTX 1060 or the Amd equivalent
  5. A 2tb hard drive and an SSD that can hold windows
  6. At least a Semi module PSU
Thanks for the help :)
https://linustechtips.com/topic/983061-building-my-first-pc/
Assuming you will buy from the US, and that you will use rebates.
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($160.98 @ Newegg)
CPU Cooler: CRYORIG - M9a 48.4 CFM CPU Cooler  ($19.89 @ OutletPC)
Motherboard: MSI - B450-A PRO ATX AM4 Motherboard  ($69.99 @ B&H)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-3000 Memory  ($124.99 @ Newegg)
Storage: Crucial - BX500 240GB 2.5" Solid State Drive  ($44.99 @ Amazon)
Storage: Western Digital - AV-GP 2TB 3.5" 5400RPM Internal Hard Drive  ($54.19 @ Amazon)
Video Card: EVGA - GeForce GTX 1070 Ti 8GB FTW2 GAMING iCX Video Card  ($409.99 @ B&H)
Case: Thermaltake - Core G21 Tempered Glass Edition ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($56.08 @ B&H)
Total: $971.09
Generated by PCPartPicker 2018-10-14 19:26 EDT-0400
https://linustechtips.com/topic/983061-building-my-first-pc/#findComment-11855159
WHAT, 16gb 3000MHz memory for only $125!!
Good case, purchased it a couple days ago, but I think the price is higher now tho
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/983061-building-my-first-pc/#findComment-11855187
1 minute ago, seon123 said:
Still higher prices than it was about a year ago, for the memory.
Those were the days, but its still exciting to see them continuously drop
https://linustechtips.com/topic/983061-building-my-first-pc/#findComment-11855193
Total: $971.09
I made a few tweaks but I'm still bad at this so...
https://pcpartpicker.com/list/d3tQBb
https://linustechtips.com/topic/983061-building-my-first-pc/#findComment-11855221
Why did you switch the ram? Also, get a higher speed ram; 2400 for AMD is slow
https://linustechtips.com/topic/983061-building-my-first-pc/#findComment-11855246
The cooler is so that you can overclock the 2600. The included cooler is not that good.
8GB RAM doesn't make sense with your budget.
The G21 is generally considered a better case than the Spec 04, and costs less.
https://linustechtips.com/topic/983061-building-my-first-pc/#findComment-11855248
You would want to get a better cooler than that if you want to warrant buying one over just using the stock cooler.
https://linustechtips.com/topic/983061-building-my-first-pc/#findComment-11855260
I would agree if it were the 95W Wraith cooler, but the 65W version leaves a lot to be desired.
https://www.techspot.com/review/1635-amd-wraith-coolers-compared/
https://linustechtips.com/topic/983061-building-my-first-pc/#findComment-11855280
39 minutes ago, Teik said:
Should I try to buy this during Black Friday/ Cyber Monday or now?
Probably not. The way to save on sales is to see what's on sale, and then decide the parts. Not deciding on parts, and hoping they're on sale.
https://linustechtips.com/topic/983061-building-my-first-pc/#findComment-11855409
PCPartPicker part list: https://pcpartpicker.com/list/qZ3Hr6
Price breakdown by merchant: https://pcpartpicker.com/list/qZ3Hr6/by_merchant/
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($279.89 @ B&H)
CPU Cooler: Corsair - H55 57.0 CFM Liquid CPU Cooler  ($49.99 @ Newegg)
Motherboard: ASRock - Z370M-ITX/ac Mini ITX LGA1151 Motherboard  ($126.88 @ OutletPC)
Memory: Corsair - Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($69.99 @ Amazon)
Storage: Samsung - 860 Evo 250GB 2.5" Solid State Drive  ($55.99 @ Amazon)
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive  ($59.89 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($239.00 @ B&H)
Case: NZXT - H500 (Black) ATX Mid Tower Case  ($61.00 @ Amazon)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.89 @ OutletPC)
Total: $992.52
Generated by PCPartPicker 2018-10-14 22:23 EDT-0400
Former Bronze Contributor
CPU: Intel i7-7700K 4.2 GHz / CPU Cooler: Cryorig H7  / Board: ASRock Z270 Taichi / GPU: Nvidia 1060 6gb EVGA SC / GPU Cooler: NZXT Kraken G12 with Thermaltake Water 3.0 120mm RAM: White Corsair Vengeance LPX 16GB DDR4 2666 MHz SSD: 2x Samsung 850 Evo 250 and 3TB WD blue HDD / PSU: Corasir 550cx / Case: NZXT s340 Elite White
Im a super Italian. Kapish.
https://linustechtips.com/topic/983061-building-my-first-pc/#findComment-11855623
Yes but you still want to get a better aftermarket cooler than that. I mean it doesn't seem like a justified purchase unless you get a decent one.
https://linustechtips.com/topic/983061-building-my-first-pc/#findComment-11856080
  1. Under $1000 USD
Something like this should be a good starting hand...
CPU: AMD - Ryzen 7 1700 3GHz 8-Core Processor  ($179.99 @ Amazon)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($118.98 @ Newegg)
Video Card: Gigabyte - GeForce GTX 1080 8GB Turbo OC Video Card  ($444.98 @ Newegg Business)
Total: $1054.19
Generated by PCPartPicker 2018-10-15 02:43 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/983061-building-my-first-pc/#findComment-11856113
