18 minutes ago, DotzHyper said:
If u do a stress test and the fans don’t work, I don’t think they are plugged in all the way
they work, they just start to run at higher temps, should be controlled by bios i imagine, i just wanted them to start running at lower temps.
14 minutes ago, peacefulpolarbear said:
If you google “wattman fan control” it seems to be an issue with the software. A bunch of people have said the same thing
ok, good to know, i guess there must be something wrong with Wattman then. Thanks.
