Hi all,
I am a self-build virgin so any advice you can provide will be greatly appreciated.
1. Budget & Location
Based in the UK with a budget up to £2,000.
2. Aim
Primarily RTS and RPG gaming.  Secondary functionality will be RAW image processing.
3. Monitors
Initially one monitor with the possibility of expanding this to a second in the future.  I definitely require advice in this area!
4. Peripherals
OS required as I currently have a Mac Book Pro as my main personal computer.
5. Component Ideas:
Case                                          Corsair 650D                                £139.99
Processor                                  i7 4770K                                       £255.80
Ram                                          ? Help Please
Cooling                                      Corsair  H100i                               £87.99
Storage SSD                             Samsung 256Gb 840 Pro              £176.70
Storage HDD                             Recommendation required
Motherboard                             Asus Maximus VI Formula S1150 £225.98 (based on a Tom's Hardware recommendation)
Video Card                                MSI GTX780Ti Gaming Edition     £551.74
Power supply                            Corsair 860W AX860i Platinum     £152.55
Any recommendations or alternatives to the above would be greatly appreciated.  Advice on a monitor, RAM, and a HDD would be especially appreciated.
Thanks in advance.
https://linustechtips.com/topic/98179-first-self-build-advice-required/
For the HDD either a WD Green (because you already have an SSD) or a Seagate Barracuda.
Considering how powerful the 780ti is I would go for a 780 instead then spend that money on the additional monitor that you were going to purchase in the future.
So I spelt something wrong in my post... I don't care I don't read through what I write and I type very quickly.
Intel 3770k stock, MSI Z77A-GD65, MSI GTX 760, Corsair Vengence DDR3 1600Mhz 16Gb, Corsair RM 550W, Samsung 830 256Gb, some random hdds.
Hi all,
2. Aim
3. Monitors
4. Peripherals
5. Component Ideas:
Ram                                          ? Help Please
Thanks in advance.
do you need a keyboard and a mouse?
edit: also, you don't need that fancy motherboard, it won't help you with anything
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
Hi all,
2. Aim
3. Monitors
4. Peripherals
5. Component Ideas:
Ram                                          ? Help Please
Thanks in advance.
CPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  (£250.43 @ Ebuyer)
CPU Cooler:  Corsair H100i 77.0 CFM Liquid CPU Cooler  (£87.99 @ Amazon UK)
Motherboard:  MSI Z87-GD65 Gaming ATX LGA1150 Motherboard  (£138.10 @ Amazon UK)
Memory:  Patriot Viper 3 8GB (2 x 4GB) DDR3-1600 Memory  (£59.99 @ Amazon UK)
Storage:  Samsung 840 EVO 250GB 2.5" Solid State Disk  (£119.00 @ Amazon UK)
Storage:  Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£60.00 @ Aria PC)
Video Card:  Gigabyte GeForce GTX 780 Ti 3GB Video Card  (£523.57 @ Dabs)
Case:  Corsair 650D ATX Mid Tower Case  (£137.39 @ Aria PC)
Operating System:  Microsoft Windows 8.1 - OEM (64-bit)  (£85.51 @ Amazon UK)
Monitor:  LG IPS234V-PN 75Hz 23.0" Monitor  (£119.20 @ Amazon UK)
Keyboard:  Filco Ninja Majestouch-2 Wired Standard Keyboard  (£126.00 @ Amazon UK)
Mouse:  Razer DeathAdder Black Edition Wired Optical Mouse  (£47.38 @ Scan.co.uk)
Total: £1911.54
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-01-05 19:56 GMT+0000)
hope you like it
Be more specific--what do you mean by raw image processing? What are you doing it for? Programs being used?
Hi all,
2. Aim
3. Monitors
4. Peripherals
5. Component Ideas:
Ram                                          ? Help Please
Thanks in advance.
Your build is very similar to what I want to build. I wouldn't go with the Formula. There is no real benefit than going with the Maximus VI Hero which is like $100 cheaper. I would recommend Western Digital for your Storage HDD but Seagate is a lot cheaper. For your memory I don't think there is anything better than Corsair Vengeance Pro.
Thanks for the advice, I was all at sea looking at motherboards.
No mouse/keyboard is necessary.
Any tips on monitors? Thanks.
Hi I do a fair amount of nature photography so the system will be used for the processing of the RAW files. Photoshop/Lightroom will be used.
Depends on if you want 120Hz TN panel or a nice 1440p/1080p IPS Panel.
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
If he's editing and retouching photography then IPS is the way to go.
I'd recommend something like this: http://uk.pcpartpicker.com/p/2wUF9
Save the rest of the money for upgrades.
