I figured this should go. I have not used shadowplay in a while and I just started using it for highlights. Highlights works fine and saves to the temporary folder that it should. Now the instant replay feature (shadowplay) is directed to a folder as it should. When I go to save something 5 minutes ago it says that it is saved to the folder, when I open the folder it is blank. The regedit files have data encoded in both the temp and default folder but it is not appearing. Many people on other forums are having this issue. Does anyone know a solution??? The videos are not in the default video folder either nor the temp. Help would be appreciated.
https://linustechtips.com/topic/980374-shadowplay-troubleshooting-help/
