Help backing up my pc
Go to solution Solved by vanished,
5 minutes ago, ice856 said:
entire system
You will want to do an image then for sure.  You can try the built in tool, which should work but personally I don't have experience using that function of it.  EaseUS would also do it, and that I have personally used with success.
However, I would advise getting an SSD as a boot drive, it will make a tremendous difference to your overall experience.
My HDD is around 4 years old so i think its time to upgrade to a new one.
I can't buy the hard drive until next month ,I'm afraid my old drive dies before end of the month so i want to back up my system and keep it on my extHd and restore it later in to the new hard drive.
can i use Eseus to do backup to backup my system  and restore it to a new hard drive?
My backup size is 148GB and I'm planing to buy a 1TB hard drive.
Thanks
PC Spec :
Processor : AMD Ryzen 5 3400G  ; Motherboard : MSI B450 A-Pro MAX ; RAM : Corsair Vengeance LPX White 2 x 8Gb
GPU : Sapphire RX 5500 XT 8GB Pulse ; PSU : Cooler Master MWE Gold 750W, 80+Gold ; SSD : Samsung 860 EVO 250GB ; HDD 2 x WD Blue 1TB 3.5" ; Toshiba 1TB 2.5"
https://linustechtips.com/topic/980073-help-backing-up-my-pc/
Are you just backing up files or your entire system (OS and programs)?
https://linustechtips.com/topic/980073-help-backing-up-my-pc/#findComment-11828146
entire system
PC Spec :
https://linustechtips.com/topic/980073-help-backing-up-my-pc/#findComment-11828147
entire system
https://linustechtips.com/topic/980073-help-backing-up-my-pc/#findComment-11828158
What he said, just move your most used files on to a 250GB SSD to take the strain off your HDD, not to mention it is a huge improvement over HDD (nVME isn't worth it though, I can't feel the difference between my 250GB 970 Evo and my 1TB SATA drives)
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/980073-help-backing-up-my-pc/#findComment-11828186
You could clone to drive or use something like Syncredible and just run a copy routine of your most important data from one drive to another. It is what I do and works really well. My 4TB RAID gets copied to a 4TB external drive. I just have it set to look for anything that has changed and only copy the changes.
Be sure to @Pickles von Brine if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | ASUS KO RTX 3070 UnderVolted and UnderClocked | Gigabyte Aorus Elite AX X570S | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 x2 | Sandisk Skyhawk 3.84TB SSD
https://linustechtips.com/topic/980073-help-backing-up-my-pc/#findComment-11828545
Thanks i already back up my system with easeUS.
Im planing to upgrade to ssd but for now i need more storage space and my budget only enough for new hdd and my motherboard only support sata2 and i heard that ssd on sata2 does not give much differences in performance. Thanks for the advise btw
PC Spec :
https://linustechtips.com/topic/980073-help-backing-up-my-pc/#findComment-11832625
 just so you know when it is time to upgrade, sata II will cap your max sequential speeds, but what really makes SSDs feel so much faster than HDDs is the massively improved (~10x - 100x) random speeds, and those will not be inhibited by sata II
https://linustechtips.com/topic/980073-help-backing-up-my-pc/#findComment-11833626
Exactly. An SSD really does give life to an old machine.
https://linustechtips.com/topic/980073-help-backing-up-my-pc/#findComment-11834983
