Ryzen 5 1600 stock cooler or 3rd party?
datvu4202
Will the ryzen 5 1600 face any problems when running with a stock cooler for light streaming? (Aprox. 2-3hrs per day)
I have an option with the ID Cooling SE-214RGB, what is your opinion on that heatsink?
Nah, the stock cooler can handle an OC to 3.8GHz or so as well, it's pretty darn awesome.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
The ID cooling will be better, but the stock cooler is a great cooler. I believe the 1600 comes with the wraith spire, and the Wraith stealth is already such a good option, so the spire will be even better. If you want to get some better overclocking done though, just use the ID cooling tower.
Primary PC:
OC shouldn't be the top priority for my purpose, and even so, i would just OC it to 3.4- 3.5Ghz, is it a problem then?
The stock cooler is decent and you shouldn't have any issue running at stock. For overclocking you are going to have to watch voltages and thermals to see what the cooler can handle because what voltage and clock speed you clock too will affect the best of the cpu and how much thermal energy the gpu cooler needs to dissipate.
Honestly the stock heatsink is pretty darn good. Unless you want to throw money into the aesthetics pool I don't see a point upgrading from it.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
In that case just use stock
Primary PC:
You can get away with alot more than that. You want to overclock to 3.7 at least. The voltage requirements up until after 3.7 are very small so you don't take as much of a hit on heat as you would when having to increace the voltage a bunch. I mean my 1700 actually ran cooler running at s manual overclock of 3.7 because I was using less voltage than stock settings which tend to put voltage on the safe side aka way more than is nessisary.
And what are the temps?
I honestly can't remember off hand as it was a right when it came out so around a year and a half ago and I am now using the 2700x and gave the 1700 to my brother.
So in conclusion, I shouldnt be worry about the temps getting too high?
