Multi-posting
Go to solution Solved by colonel_mortis,
I think this issue should now be resolved.
I've noticed that some users would tend to post multiple topics (duplicates) due to gateway problems, just wondering if it's a problem on their end or if it's because of some server issues.
I only started noticing them after the latest update (unless this isn't something new), so maybe that has something to do with it.
Edit: I also experienced it while posting this topic
Edit 2: I think it also affects status updates, saw a duplicate, but it's not enough for a conclusive answer
image.png.8df428bb2a1a4b6c4a235849ffac4e9f.png1861770456_Screenshot_2018-10-04LinusTechTips.png.df213f40f958950925bce71f18470f93.png
https://linustechtips.com/topic/979135-multi-posting/
