coulkd someone please help me. i boot my PC up perfectly fine then about 10 mins into it been turned on it sometimes just black screens and the when i restart it i get a overclocking failed boot page... i have not overclocked the pc and i have reset the bios and cmos. what else can i do.
Thanks a lot
https://linustechtips.com/topic/978774-please-help/
33 minutes ago, Dakesy3211 said:
its not overclocked at all i have reset it all
What cpu? Did you double check that voltage and core clock are on auto? Also make sure your memory is running at the lowest standard for its memory type such as 2133 for ddr4.
https://linustechtips.com/topic/978774-please-help/#findComment-11815627
as for specs
    Intel Core i7 5930K @ 3.50GHz    27 °C
    Haswell-E/EP 22nm Technology
RAM
    16.0GB Unknown @ 1065MHz (15-15-15-35)
Motherboard
    ASUSTeK COMPUTER INC. X99-A (SOCKET 2011)    23 °C
Graphics
    BenQ XL2411Z (1920x1080@144Hz)
    S236HL (1920x1080@60Hz)
    SMS19A200 (1440x900@60Hz)
    4095MB NVIDIA GeForce GTX 1070 (EVGA)    37 °C
Storage
    2794GB Seagate ST3000DM001-1CH166 (SATA )    23 °C
    476GB Samsung SSD 850 PRO 512GB (SATA (SSD))
https://linustechtips.com/topic/978774-please-help/#findComment-11816217
23 hours ago, Dakesy3211 said:
as for specs
RAM
Motherboard
Graphics
Storage
why does the ram show up as unknown?
after reseating the other equipment did it crash?
i know this may sound stupid, but was the thermal paste applied properly and was the safety sticker taken off the aluminum/copper plate?
https://linustechtips.com/topic/978774-please-help/#findComment-11818838
i dont know hwy it shows up unknown, i havent changed anything and it has been running perfectly fine for the past couple of days now. and yeah thermal paste and everything is applied properly only thing i can think of at this stage is a dodgey stick of ram
https://linustechtips.com/topic/978774-please-help/#findComment-11819845
