Does Deepcool makes decent fans?
gbmike
My case has 5 fans support and only come with 1 rear fan. Considering to add 4 of Deepcool Xfan 120. Are they good budget case fans? I was looking for NZXT FN-120 V2 and found the Xfan 120 with almost same spec and near 1/3 of the NZXT price.
they are pretty decent but haven't used those fans specifically
Current build: Ryzen 7 1700x, asus prime x370-pro, 16gb gskill trident z rgb, asus rog strix gtx 1070 ti, corsair rm650x, nzxt s340 elite, samsung 840 pro 256gb, 1.5tb hdd.
I've also had good experience with the Arctic fans as a budget option.
I would expect the Deepcool ones to be fine, but unspectacular, in much the same way as most budget fans are. They will work, they will move air, they will be moderately quiet if the RPM is reduced.
I wouldnt spend too much time looking at fan specifications though, all manufacturers measure it differently and/or just pull figures our of their arse.
As a budget option I always tell people to get the CoolerMaster 4 pack of 120mm fans.  I buy the 4 pack anytime its on sale for backup fans, usually pay $8-9 bucks for 4 decent fans (remember we are talking budget) - yeah you get mustard and ketchup colored wires and no sleeves but its a budget!
Ive never had bad issues with CM fans.  The only ones that die on me are lifecycle, and even then I can usually use some silicon and get some more miles out of them before they don't work completely.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Both fans are similar in that they're either noisy at max rpm or don't push a lot of air a low rpm. They're passable as stocks fans included in a case but I wouldn't recommend buying them separately.
What are your specs and budget? Can you link us to where you're shopping?
USD10 or less for 2 fans. Only need them as temporary fans since Noctua or other good fans are expensive if you buy 3 or 4 of them.
What are your specs? Can you link us to where you're shopping?
Since you say temporary probably these would be your best option maybe:
https://www.amazon.com/uphere-3-Pack-Computer-120mm-Cooling/dp/B072LDYKQ6/
Current computers:
Primary Computer (In Progress):
SUBJECT TO CHANGE
CASE: ROSEWIL THOR V2 Black
CPU:
Motherboard:
GPU: SAPPHIRE VEGA 56 -TBU RTX 2070 SUPER
RAM: 48 GB CORSAIR VENGEANCE LPX
PSU: SEASONIC PRIME 1300 W GOLD
STORAGE: 4x SEAGATE EXOS 4TB | Sans Digital HDD 5-Bay Rack | Sisun IDE SATA HDD Docking Station
SOUND SYSTEM: Logitech Z506 Surround Sound via Vantec USB External 7.1 Channel Audio Adapter
MOUSE: 16000DPI GAMING MOUSE
KEYBOARD: -PENDING-
MONITOR: -PENDING- AOC AGON AG241QX 24" -PENDING-
COOLING:  CPU: Noctua NH-D15 -3x NF-F12 Fan MOD || 10-12X NF-F12 || EXHAUST: 3x NA-A12x25
LAST UPDATED 4/29/20
Secondary Computer:
CPU: AMD FX-8370 Black Edition
Motherboard: ASUS M5A97 R2.0
GPU: Zotac GeForce GTX 970 AMP! Omega Core Edition
RAM: 24GB Kingston HyperX Savage 1600MHz DDR3
PSU: Antec High Current Gamer HCG-900W
STORAGE: 5x Western Digital Black 2TB - WD2003FZEX | Sans Digital HDD 5-Bay Rack | Sisun IDE SATA HDD Docking Station
MOUSE: PUREX 2400 DPI Wired Laser Gaming Mouse
KEYBOARD: DBPOWER 104 Key -3 Backlit -I KNOW! Linus doesn't approve -I have glued it to the desk and it works well for my needs.
MONITOR: ASUS VS247H-P 24 Inch
COOLING: CPU: Noctua NH-D14 -3x NF-F12 Fan MOD || 10-12X NF-F12 || EXHAUST: 3x NA-A12x25
GRAPHICS: 2x NF12s fans on graphics card + 2x NF-F12s & 1x NA-A12x25 in Fan box | 1x Vantec SP-FC70-BL Spectrum System Fan Cards
Ryzen 3 1200 @ 3.8Ghz
Asus Strix GTX 970
Asrock AB350M-HDV
Team T-Force Dark 3000Mhz
etc
From Indonesia
Asus Strix GTX 970
Asrock AB350M-HDV
etc
From Indonesia
What case are you using? Are there any shops you can link us to?
Thermaltake Versa H18
tokopedia.com if that could help
The stock rear exhaust and a TY147ASQ front intake should be plenty for cooling. https://www.tokopedia.com/redcomp/thermalright-ty-147asq-fan?trkid=f=Ca312L000P0W0S0Sh00Co0Po0Fr0Cb0_src=universe_page=1_ob=3_q=thermalright_po=27_catid=312&lt=/searchproduct - p6 - product
