I keep having issues with SLI on my two GPU's, I thought maybe someone here has a solution.
This is the error I keep receiving, I was trying to launch BF4 Test Range, I also tried it on 3D Mark and it just made my system hang.
I've done a clean install of the drivers, tested both beta and official drivers and nothing has worked so far. If anyone can help me with this it would be greatly appreciated.
System Specs:
 AMD 8350 Stock
 Asus Crosshair V Formula Z Motherboard
 2x MSI Twin Frozer GTX 770s (2GB)
 8GB Kingston HyperX Memory
 EVGA 750G PSU
 128GB SSD
 1TB HDD
Windows 7 Ultimate
https://linustechtips.com/topic/97767-issue-with-770-sli/
i get that kind of errors with unstable overclock on my 7850 xfire
https://linustechtips.com/topic/97767-issue-with-770-sli/#findComment-1307700
Are you getting that error at stock clocks?
https://linustechtips.com/topic/97767-issue-with-770-sli/#findComment-1307744
Stock as in I haven't changed anything, yes.
 Remove and install drivers using this method http://www.overclock.net/t/1150443/how-to-remove-your-nvidia-gpu-drivers.
Maybe even revert to older drivers like 331.82 (I'm having no issues with these).
https://linustechtips.com/topic/97767-issue-with-770-sli/#findComment-1307780
I've already done that. I used drivesweeper, it didn't hep.
https://linustechtips.com/topic/97767-issue-with-770-sli/#findComment-1307939
