So i had a issue where i had to replace my motherboard about 2-3 months ago and it was working just fine and i deiced to test the 2-4 ram slots i mean the other 2
and when i tried to boot up my pc i got a error code and i reserched it and it said it was the ram so i was like okay... so i tried the same sticks in the 2 other slots and they worked
so the ram is fine but the slots won't work. when ram is in the computer won't post, so i tried flashing the BIOS updating it
didn't work
I tried to mess with the jumpers
didnt work
but today i managed to make the computer boot with the 2 rams sticks in the broke slots but it didn't detect the ram. it said 2.00GB and i was like What......
anyway so i took the ram out and put it back in and it wouldn't boot so i switched the jumpers back and i said screw it and didn't try anything else
What could this be. cause i could have 8gb of ram if my computer didn't do this
and im so confused
https://linustechtips.com/topic/977653-someone-help-me-ram-issue/
Probably your motherboard has atleast 1 dead ram slot, or it doesn't like booting with ram in the wrong slots. So try each slot one by one with 1 ram stick and see which one is broken, and read the manual, if the computer likes to boot with ram only in 2-4 slots.
I only see your reply if you @ me.
You didn't specify what CPU you have. If you have an LGA slot, remove the CPU and inspect all of the metal contacts in the slot for damage or contamination. While you have it out, check the CPU pads for contamination as well.
There's no place like ~
Problems and solutions:
FreeNAS
Dell Server 11th gen
ESXI
