hi all.
basically im looking for as small a case as possible to fit this
http://www.asrock.com/mb/Intel/H61M-DGS/?cat=Specifications
i think the micro cases are just too small.its to fit in a cupboard under the tv so thats why i want such a small case.
any help gladly wanted
(edit) i forgot to mention that i need it to be no more than 350mm/13 inces deep (front to back)
https://linustechtips.com/topic/97729-smallest-case-possible/
https://linustechtips.com/topic/97729-smallest-case-possible/#findComment-1307062
Bitfenix Phenom (or Prodigy if you have the extra), EVGA Hadron, NCASE M1 (if you can find one) ?
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
https://linustechtips.com/topic/97729-smallest-case-possible/#findComment-1307069
silverstone ft 03 mini or Lian Li TU-100B
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/97729-smallest-case-possible/#findComment-1307077
Fractal core, why its a matx case, a crap one at that.
Listen if you care.
https://linustechtips.com/topic/97729-smallest-case-possible/#findComment-1307130
thats perfect.
just more than i want to spend lol
https://linustechtips.com/topic/97729-smallest-case-possible/#findComment-1307242
