building a pc.
use case: web surfing, 1080p streaming, coding in c++ and python, light gaming at 1080p medium settings( mostly car games and fps, not AAA though)
help me decide between ryzen 7 1800x and the new shiny core i5 8600.
I will pair both with one 8gb stick.
https://linustechtips.com/topic/976507-help-decide-cpu/
Ryzen, though if you want to save some money, a 1700 will do just fine
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795125
the cheapest 8th gen i5
Desktop benching:
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795126
a ryzen for sure, since you are quite productive and not having a high end GPU, the cores & threads wont disappoint you.
BTW see if you can get R7 1700 and OC for similar performance.
and  one 8gb stick ram is not recommended , just get a pair of anything
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795130
thanks. I'm planning on getting a mobo with just 2 ram sticks. I'll have one 8gb stick at 2666 or above and upgrade it later. will it bottleneck. I'm aware ryzen benefits from high speed memory.
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795134
I don't think you shoud get the i5. I strearm on an i5-8600k +16gb ram + 1080 gpu and I'm not getting smooth 720p 60fps using the cpu. I suggest going Ryzen, factoring the overclock it probably is way better than the i5 for streaming.
Current Build
CPU: AMD Ryzen9 5900X
CPU Cooler: Deepcool Gamerstorm Captain 240 Pro
Motherboard: ASUS ROG STRIX X470 Gaming-F
Memory: G.Skill Trident Z Neo RGB F4-3600MHzC16D 2x16GB
Video Card: EVGA 3080Ti FTW3
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case
Power Supply: EVGA SuperNOVA G2 850W 80+ Gold Fully Modular
Case Fans: 2x Noctua NF-P14s redux-1500 PWM 78.7 CFM  140mm Fan
Monitor: HP x34
              LG 29UM69G
Mouse: Razer Basilisk
Keyboard: Razer Blackwidow Chroma V2
Controller: GameSir Tarantula Pro
Headphones: Sennheiser IE200 + Fiio BTR5 2021
Speakers: Logitech Z200 2ch Speakers
OS: Windows 11
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795135
3 minutes ago, _ashwin_ram said:
why should i go with the i5?  with the ryzen I can overclock it slightly and have the extra threads.
because you only have a single stick of memory, and I assume it's a slow ~2400MHz one
if you can save some money by using a cheaper Ryzen 7 instead and buy another stick of RAM, then Ryzen is better.
Desktop benching:
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795136
1 minute ago, Srishunbagasundaran said:
I don't think you shoud get the i5. I strearm on an i5-8600k +16gb ram + 1080 gpu and I'm not getting smooth 720p 60fps using the cpu. I suggest going Ryzen, factoring the overclock it probably is better than the i5 for streaming.
just went through your pc specs. nice hardware man. thankss..
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795141
all g
Current Build
Monitor: HP x34
              LG 29UM69G
OS: Windows 11
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795145
also applications like chrome, office and vs code benefit from faster cores than multiple right?
games now support multiple cores.
with more cores nowadays, programs are not well utilized and not quite efficient....
but the task you mention are all light tasks, they use only very little cpu power compared to ryzen.
ryzen is definitely overkill for these purpose
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795164
Get the i5 8600 or Ryzen 7.  ashwin I don't know why your not getting a sustained 60fps hmmmm.  I get a sustained 60fps in Quake Champions and Unreal Tournament with my pos video card.  Also the CPU usage is 15 percent avg on both games.  Theres like 85 percent sitting there doing nothing.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795167
what about streaming. 1080p. just youtube or netflix.
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795169
For me youtube full screen or netflix takes up couple percent CPU power.  Maybe 8 percent or so.
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795174
I believe next month, but I wouldn't put my life on it, but that is what Ive been hearing.
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795187
So, I was under the impression by streaming you meant streaming to twitch/youtube. Not, watching netflix, my bad. The i5 is definitley good for gaming.
Current Build
Monitor: HP x34
              LG 29UM69G
OS: Windows 11
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795190
1 minute ago, _ashwin_ram said:
yeah me too. minor improvement but with the release of the 9th gen cpus, the price of the 8th gen cpus will decrease right?
just wait and see, imo just another disappointment of the year,
but really going for i5 6 cores for streaming? good luck then
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795202
I should've been clear. thanks
it's all good.
But yeah, i5 is good for gaming and 8gigs ram is technically enough, but go for 16 if you can. Chrome uses a lot of ram, it's kinda ridiculous.
Current Build
Monitor: HP x34
              LG 29UM69G
OS: Windows 11
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795212
Just now, Srishunbagasundaran said:
it's all good.
thanks.  and hey i"m from India too xP. Namaste _/\_
https://linustechtips.com/topic/976507-help-decide-cpu/#findComment-11795217
