Working on a new build that is using mostly Corsair LL series (120/140) fans and 3 generic'ish 50mm fans on the back mounted over the expansion slots.
Am hoping to use a fan controller.
I have 4 primary groupings for the fans:
2 LL140mm in front (filtered intake)
3 LL120mm on top for the Corsair cpu radiator (filtered intake)
3 50mm in back (unfiltered exhaust)
1 LL140mm in back (unfiltered exhaust)
Id like to group these fans using pwm hubs for the 4 primary groups listed above but I am having troubles finding fan controllers/pwm hubs that are comparable.
Does anyone have any recommendations?
https://linustechtips.com/topic/975211-new-build-needs-pwm-fan-controller-help/
Corsair Commander pro?
