My case has too much airflow. Honestly, i just want to build a computer inside of a vacuum (for science)
Inside a vacuum, would it still emit heat as we know it, or would it emit heat in the form of radiation? How can i turn my horrible concept into a reality?
please just let me be a dumb ass
https://linustechtips.com/topic/974098-case-airflow/
  Reveal hidden contents
You will radiate heat in form of IR radiation. Heat has 3 ways to transfer conduction, convection and radiation. Vacuum is perfect insulator so there won't be any conduction or convection.
As far as how to achieve it, you will need a durable case that can sustain vacuum. Seal it airtight, hook up a vacuum pump and keep sucking the air out. How low the pressure can go will depend on durability of your seals, case and pump capacity.
CPU i7 8700k MB  Asrock Z370 Killer SLI/ac GPU EVGA GTX1060 6 GB RAM 16GB DDR4 Gskill Ripjaw 3200 Mhz PSU EVGA SuperNova 750 G1+Storage 1x1TB WD Blue + 250GB WD Blue M.2 CASE Fractal design define C
https://linustechtips.com/topic/974098-case-airflow/#findComment-11774007
Heat needs to transfer to somthign to mvoe away from your components. in a vacuum the heat has nowhere to go.
People have made air tight cases for PC components before, but they pump in a dry inert gas to take the place or normal air. This is usualy done to removem oisture from the air and thus stop condensation from formign when running sub ambient cooling solutions.
its a common misconceptin that a vacume, like space, is super cold. A vacum isnt cold, space isnt cold becouse its a vacume, its cold becouse there is no heat source when there is no direct sunlight (space is cold though). In space without a space suit you would die from asphyxiation and the bends long before freezing to death. And in direct sunlight you would burn up.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/974098-case-airflow/#findComment-11774011
Just yeet your rig into space.
https://linustechtips.com/topic/974098-case-airflow/#findComment-11774014
airflow is overrated. do you propose this could work if i could keep the air density of the case down?
thought about it but i don't have long enough cables to reach my monitors or keyboard
https://linustechtips.com/topic/974098-case-airflow/#findComment-11774207
also space dust
https://linustechtips.com/topic/974098-case-airflow/#findComment-11774212
