A splitter limits it to 100mbps.
Get a switch if you want it to be futureproofed, if you have a NAS or if your internet speed is above 100mbps.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/973881-ethernet-splitter/#findComment-11771919
4 hours ago, beersykins said:
Never go the splitter route.
Just add a switch on the end.
Can a switch be used to connect both devices at once? The name makes it sound like it switches between the two, I need to be able to use both at the same time. Thanks :)
https://linustechtips.com/topic/973881-ethernet-splitter/#findComment-11772724
Pretty much really, plus there are some cheap ones that you can find that would basically cost you the same as a splitter. Something like this seems cheap and simple, of course just be sure to have a place you can plug it into, since it's gonna need power.
https://linustechtips.com/topic/973881-ethernet-splitter/#findComment-11772748
The term is related to packet/frame switching and not circuit switching.  It will extend your network with extra concurrent ports.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
https://linustechtips.com/topic/973881-ethernet-splitter/#findComment-11773218
